o0o sounds interesting!ill come check it out on sunday when im there. the saturn black actually matched everything else in the car and the dash around it very well.he was very happy with the result.i use the same paint on my plastics in my 33 but with a clear over the top.looks sexy as with a clear but abit shiny so i think ill go back to just the plain saturn black without a clear.
does willall racing have a website? anyone?
any one had experiences with them?
yeh i had my forged engine built by them, they did a great job.....but then again that was when peter hall was still working there, he was very heplful with alot of experience with all skylines
planning of taking mine there soon 2 compare their tune with simon's tune
what paint are you using? the paint i use is chemical resistant,heat proof to 500c i think it was,and scratch resistant.i havnt been able to scratch it at all once its set.altho i do go over board with the clear coat so it really gives a deep glossy look to the paint.
ah yea,iv never tryed that stuff.i mainly use VHT stuff so it is esentially caliper paint lol.
i have been doing some searching and it seems no one is activly making SAU stickers any more? if the demand is there im happy to supply some more to order.
i take it you mean morpowa simon??
thats why im going there, see if they can pull more out of it, im just not confident
simon spent quality time on the tune in half a day inc install.....
i think its able to run more boost with the supporting mods i have.
Haha yeah kudos to you in the hills Ryan, left me and my non grippy Wanlis and lack of power behind!
thanks mate
well mine feels far from ''amazing'' at the moment, laggy as all f**k,
im taking it to wilall racing soon, im sure its capable of more....its felt better than this.
i just dont feel simon spent much time on a quality tune.
didn't you mention something about white smoke a few days ago, also HOW laggy? shouldn't be laggy at all with a highflow.
hahaha got a few bites on the r33 boaty thing. :thumbsup:
haven't been reading any of my posts? I went and compared jeff from THE SPEED LAB and a Tune by Martin Donnon (willall racing) and there was a noticable difference and i highly reccommend. No website, Look below for their number.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
