can u get me a cheap greddy cooler jack??? or anyone?? hahaha
lol well seems i left autobarn a little while ago i can probly only get you mates rates lol. your about a month and abit too late ahaha....theres a cheapo kit sittin in my shed tho...
ahaha only an hour and 40 mins to go joel! in the mean time you can pretend your feasting on this.
*picture of jacks scrambled eggs*
Honestly, the BEST scrambled eggs i have ever had!!! :(
-1 goes to that Autosalon $5 coupon for the entry fee...
In small writing, it says "Must be printing in colour - black and white entires will not be accepted"
Pffft... and where am I meant to find a colour printer in this building?! Stupid cheap black only photocopiers...haha
I have a spare one, thanks to my lovely school printers lol and Damo was printing off some too? :down:
is that karas bf?
if it is has he painted his front bar yet lol.i got that cooler for him too haha!
Yeah dude, Reece! That's Kara's bf haha how do you know Kara? I met her via Hayley (Robbie's gf... he has a white S13 with a Nismo sticker along the rear windshield)
Oh hang on... now I remember Kara talking about you!! Reece got shitty because apparently Kara wanted to go to Autobahn all the time to talk to you or something? haha... yeah that 180 is a thrash car now. me and him go sliding in it all the time around the backstreets of Hallett Cove. He's got a leaking strut + stuffed gearbox + really, really poor engine rebuild.
Fun car to thrash around in, though.
When you come to a cruise, then you will know :down:
Hahaha now heres the funny thing. The next cruise i'll be going on is my OWN cruise that im organising....so maybe YOU should bring the name tags hahaha...seeming as you wont tell me....selfish bum lol :(
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
