Ok, installed an air vs fuel ratio meter that i got form jaycar... now its not the most accurate thing out there... but the fact that i built it and wired it in
merits some satisfaction :P Just thought i'd share! :D Oh coincidently the alarm beeps when i need to change gears! WOO
Edit* Looks cool at night too!! with all the little LED's dancing around XD
Joel you need to learn to read thats twice now you've been given an answer today and you still asking the same question
i told you up the said check your afm elec. Cleaner might not be enough Damo there over 20 years old
my car almost got defected :D
luckily i got an awesome cop who has given me a week to get EVERYTHING fixed
he did say if he sees it on the road next week in the same condition he will defect it.
oh and my suspension is too low :P which is weird coz no1's lowered it unless my
brother did it it without me knowing lol
yes, yes i do. went from a job with random hours at a low-ish pay rate to working the last 3 month with consistent hours at a high-ish pay rate this = mega tax refund!!! =)
same! thankyou ATO :P
What do you mean Joel? The plug
you need to unbolt the whole lot and spray the needle on the inside and dont use degreaser
lol damo ner ner...
could be.... i pulled the top AFM off to clean it but it was already sparkling so i didnt bother about the other 1.... maybe its worth looking at...
those chromies on your car damo look crazy when the spokes are painted with 2pac gloss black! a mate of mine did it and they're not bad at all
I was going to say the same thing :P They look pretty good but would look alot better with black spokes
200-300 for the front bar sprayed maybe?
but when i went to arnedale to pick up my mum there was a freaken RBT on the street where the carpark is where bunny had her cruises! cop asked if i had a bov i said yes and it's stock, he let me through :P
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
