thats not too much... i need to get the front bumper resprayed asap so I can add a few finishing touches of my own before fitting it back up :P
this is what I did...
the blue/shiny bits will be hidden behind the bumper - though it looks nice like that with the bumper off the blue and the bling breaks off the black nicely haha
I was considering painting just the piping but photoshopped it thought it looked a bit odd so I did the whole thing heat resistant black, no primer - will black mesh off the middle section and wrap the pipes in something else black I reckon coz not sure how well the paints going to hold up on the sides there - the chrome hardly stayed shiny with rocks and bugs flying at it!
well steve/damo pretty sure you guys were right about the AFMs. im about to pull them off and have a look now. My car cut out 3 times on the way home from work, pretty scary lol
booked into the mechanics tomorrow morning, hopefully they can make heads or tails of it.
Quick question, anyone know if turbotune are open saturdays? Or even boostworx? Even if the car can be dropped off on a saturday and moved around the back or whatever to be worked on/looked at on the monday..
ah joel you dont need to take it somewhere (where are you taking it)
go see Wally @ Z-imports next to Roccla Besser @ ottoway grand junction rd when i was there 1.5 months ago he had 2 gtr AFM's like 60-80$ ea. from memory get them and that should sort your problems
Jarrad - boostworx is sometimes open on saturdays but i dont think he answers the phone not sure about turbotune maybe ring tomorrow and organise your drop off
Thanks guys, and girl. Might give them a call tomorrow, dont know when its going to be dropped off as yet, its being driven the night we go to pick our hoodies up. May be safe booking it in early september. Ill decide tomorrow.
DTM are out of stock in 18 x 9.5 +15 :whistling: gotta wait for their other stock to sell before access get new ones (ie they have to sell the 18x7.5 +45's etc :D ) might look at the Origin DNA01's....
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
