Wow what a shit day! First got all our work rained off the wall this morning :D Then get a phone call from the missus crying her eyes out as she had an accident. She's so f**king lucky to be alive right now, she missed a tree the size of a small car by literally 5cm. Car is a mess but that's what insurance is for, she's ok and thats the main thing. Hopefully will still be able to make it tonight :( Trying to get her out to have a bit of fun
