lol but you are :(
yeah when wreckers do front cuts most people wouldn't take heater cores so shouldn't be too hard i wrang JIS on friday for one he said $75 but i didn't ask if he had one as i went to Zimports
If you get one Craig, I'll lend a hand so long as Steven does too! We should knock it over in no time now, expert, the both of us :(
To save us time you could take out your passenger seat, pull up the carpet and make sure you soak up ALL the coolant that has leaked out and dry out all the carpet and padding. You don't want that staying wet!
Good on ya Amanda....like Ryan said, if he doesn't want to be involved in the baby's life, now's the time to show him the door.
yeah well if he decides that again then i won't say anything to him i'll walk away
but his family would still want to be involved which is good i think
Amanda if he wants to be apart of the baby its easy say its me or her make your choice wisely
if he chooses her then he has no option but if he wants to come to appointments with you he goes alone
we already talked about that except when if he has a partner after it's born.
he said "what happens if i have a gf when it's born and she gets jealous coz i'm around you and the baby"
i replied saying "they'll just have to get over it, and i hope your child is more important to you than some female"
but um i don't wanna make him choose coz i know he'll choose her, he loves her and what not
and well i'm just the baby carrier.
just realised, i'm a friggin idiot for getting pregnant to him
lol, i know, it stinks already, the funny thing is, i noticed the smell inside the car, it just didnt click.
i wont be driving for a while, so ill prob pull the seat and carpet out tomorro arvo and clean it up.
ill let you boys know when i get another core.
hey Adrian you still keen on that reo or can I stop carting it around in my car now? :(
Only just now? He seemed like an asshat from the beginning the way you described his actions.
and I see you reading Inline 6 Dan, your missus friend hella stood me up hey :laugh:
Begs the question 'why?' then doesn't it :(
coz obviously i was stupid. i do however think it's funny he thought he was leading me on
the other reason i don't want her involved at all is coz she had an abortion last year sometime
and i dunno i think she might try to take it make it yours if you know what i mean, i could just be
really paranoid but it is a possibility and it does happen so hmm
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia body...
    • This. A 3d wheel alignment is like $120...just take it to the shop. Since theres probably multiple adjustments that need to be made after changing something. Mine has front/rear lower arms, traction rods, tension rods, camber arms, toe arms, front upper arms, hicas kit, sway bars and coilovers. I measure from the edge of the bolt holes on the originals and set the same length on all the adjustable stuff to dial it as close as I could to OEM. Took it straight for alignment; it didnt feel right at all...after alignment, it feels perfect. Similarly i've just changed the springs on another car; and I still needed multiple adjustments to bring it back in spec.
    • A full Veilside kitted JZA80 Supra in Meriken park in Kobe city a few weeks back
