lol but you are :(
yeah when wreckers do front cuts most people wouldn't take heater cores so shouldn't be too hard i wrang JIS on friday for one he said $75 but i didn't ask if he had one as i went to Zimports
If you get one Craig, I'll lend a hand so long as Steven does too! We should knock it over in no time now, expert, the both of us :(
To save us time you could take out your passenger seat, pull up the carpet and make sure you soak up ALL the coolant that has leaked out and dry out all the carpet and padding. You don't want that staying wet!
Good on ya Amanda....like Ryan said, if he doesn't want to be involved in the baby's life, now's the time to show him the door.
yeah well if he decides that again then i won't say anything to him i'll walk away
but his family would still want to be involved which is good i think
Amanda if he wants to be apart of the baby its easy say its me or her make your choice wisely
if he chooses her then he has no option but if he wants to come to appointments with you he goes alone
we already talked about that except when if he has a partner after it's born.
he said "what happens if i have a gf when it's born and she gets jealous coz i'm around you and the baby"
i replied saying "they'll just have to get over it, and i hope your child is more important to you than some female"
but um i don't wanna make him choose coz i know he'll choose her, he loves her and what not
and well i'm just the baby carrier.
just realised, i'm a friggin idiot for getting pregnant to him
lol, i know, it stinks already, the funny thing is, i noticed the smell inside the car, it just didnt click.
i wont be driving for a while, so ill prob pull the seat and carpet out tomorro arvo and clean it up.
ill let you boys know when i get another core.
hey Adrian you still keen on that reo or can I stop carting it around in my car now? :(
Only just now? He seemed like an asshat from the beginning the way you described his actions.
and I see you reading Inline 6 Dan, your missus friend hella stood me up hey :laugh:
Begs the question 'why?' then doesn't it :(
coz obviously i was stupid. i do however think it's funny he thought he was leading me on
the other reason i don't want her involved at all is coz she had an abortion last year sometime
and i dunno i think she might try to take it make it yours if you know what i mean, i could just be
really paranoid but it is a possibility and it does happen so hmm
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
