hey Chad if you're serious we should go and see him together.....might get a better price for a couple of sets.
yeah, im serious. i want some new pipes before the turbos go on, im still pretty keen for those Greddy ones, just depends on the cost difference.
well i just need ones to suit 32, i have 34 front pipes now, so i'll have to modify my exhaust back to 32 specs. which should give me more ground clearance i hope.
Also dropped off my 34 gtr rims today to get painted, think im gonna get them painted the same colour as my Drift Teks.
so, got bored at about midnight, so i decided id take advantage of the half not shit weather and go out and get some pics of my car. found a pretty good spot out in port adelaide, and i stole petes spot in reynella :O, pretty cool for a church, lol.
shame the camera was acting pretty freakin weird for the last couple hours :P
we should probably just rig the lotto.
takes care of that 'work' issue.
that being said, i could go out, get myself a gambling addiction, have myself self-barred from all gaming lounges in sa, then claim work cover cause of my temptation to gamble while im at work :O
... yeah, rigging the lotto is a better idea...
is it the whole kit globes and igniters, becuase HID globes are different to halogen globes :O
Lol Steve of course it is the whole kit. however, i did buy globes to suit an R34 from 666DAN, then realised i didnt have factory HID installed, then i bought a HID kit to suit R34 minus globes.
666DAN
Yeah....666Dan, his kits are tops... make sure u specify if u need the aircon leds in addition to cluster/gauges...
also, i got an entire set of red ones that I took out to put blues in if anyone wants em
-D
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
