Anyone got any ideas, hints or tips on how to remove DOUBLE SIDED TAPE? like the kind thats been on the car for years and years - any way to remove it more easier/quicker than using a blade and a hair dryer? or am I doomed to spend a few hours of my life sitting there with the blade and hairdryer.
well vu i ripped the panel off first which left the tape on the body! i then used a razor blade and got most of it off and polished the rest off!
you can still have mayo with cheeseburgers
Edited by nos man
White spirits / mineral turps works wonders
-D
noob invasion going on ;)
ur all welcome just please stick to the rules, if u cant b fd reading em these simple rules should keep you outa trouble
1. for sale shit go's in 4sale thread
2. spotted cars go's in spotted cars thread
3. read above again if you are confused and more importantly don't f with nightcrawler he got the magic stick
Edited by Inline 6
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
