Not a bad wheel at all there Steve, still can't beleive that the shipping was more than the wheel! ;)
The dude from AM Performance mailed me his pics for dumps for the GTR and OH MAH GAWD!!!! Seriously hot shit right there! I'll give you a little sampler of what I'm looking at...
Not sure there Pete, he's messaging me back some rough prices. Gonna take my car to him on the weekend, he's gonna modify my aftermarket front pipes and make me some new dumps. I don't need the Y pipes either. I'll let you know when I know ;)
vu
try and get ya hands on that citrus smelling cleaning stuff, the shit works well, either that or eucalyptus oil
Yeah orange oil matty? I used that to get the duct tape off the boot of my silvia.
new (2nd hand) steering wheel came today from japland :D for those that care :D
Nice wheel Steve, rate it highly, had one on my old siliva, very comfy!
ok boys i never ask for help
but this time i really need some help doing my rear breaks this weekend, i have exhausted all my options with my friends first so now i come to SAU they are really bad and need doing asap
Im sure it will only take an hour of your time and everyone knows that I am always willing to help people out as i have done!
I have only 10 min left of my lunch break so sms my mobile for those of you that dont have it 0401 343 118 thankyou so much xx
Also im going to vili's for coffee this friday night ill be there at 7pm as per usuall
Thanxs again guys
Who wants to buy a JDM rock? its about 3cm long, 2cm wide - dark grey in colour... it fell out from my rear pod when I took the pods off - it came all the way from Japan! Its JDM yo! $100... bargain!
who needs CF parts when you can reduce the weight of your car by removing rocks!!! =)
Thanxs again guys
Hey bunny, have you asked Heslo? he seems to be able to help with that stuff.. I hear that all you need is beer and cake and all your problems will be solved. =)
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
