Not a bad wheel at all there Steve, still can't beleive that the shipping was more than the wheel! ;)
The dude from AM Performance mailed me his pics for dumps for the GTR and OH MAH GAWD!!!! Seriously hot shit right there! I'll give you a little sampler of what I'm looking at...
Not sure there Pete, he's messaging me back some rough prices. Gonna take my car to him on the weekend, he's gonna modify my aftermarket front pipes and make me some new dumps. I don't need the Y pipes either. I'll let you know when I know ;)
vu
try and get ya hands on that citrus smelling cleaning stuff, the shit works well, either that or eucalyptus oil
Yeah orange oil matty? I used that to get the duct tape off the boot of my silvia.
new (2nd hand) steering wheel came today from japland :D for those that care :D
Nice wheel Steve, rate it highly, had one on my old siliva, very comfy!
ok boys i never ask for help
but this time i really need some help doing my rear breaks this weekend, i have exhausted all my options with my friends first so now i come to SAU they are really bad and need doing asap
Im sure it will only take an hour of your time and everyone knows that I am always willing to help people out as i have done!
I have only 10 min left of my lunch break so sms my mobile for those of you that dont have it 0401 343 118 thankyou so much xx
Also im going to vili's for coffee this friday night ill be there at 7pm as per usuall
Thanxs again guys
Who wants to buy a JDM rock? its about 3cm long, 2cm wide - dark grey in colour... it fell out from my rear pod when I took the pods off - it came all the way from Japan! Its JDM yo! $100... bargain!
who needs CF parts when you can reduce the weight of your car by removing rocks!!! =)
Thanxs again guys
Hey bunny, have you asked Heslo? he seems to be able to help with that stuff.. I hear that all you need is beer and cake and all your problems will be solved. =)
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
