ryan, my PFC doesnt display boost :thumbsup:
simon said thats not avail. on the rb25 version :)
as cubes said, cheap map sensor will sort that out, i bought the proper adapter.
yeah +1.
Also important to note the ramp rate the tuner is using......Shoot Out Mode (200) is a waste of time for the street, should be 150 or it will definitely run in different areas of the map (detonation city) on the bitumen and up hills.
definetly pete, 150 is our default ramp rate. depending on the style of power delivery but yea mainly 150. We sometimes lower it for just 1 run to really load it up to simulate going up a hill just to be safe.
just had Ryan n the guys at AUSSIE DYNO N TUNE tune my car today had a few issues with wheelspin but after putting ryan in the boot gave it a few runs and pulled a constant 300rwkw then on the last run pulled 327.4rwkw on only 19psi with only 18 knock level!!!!!
great guys down there fully reccomend them 2 any1!!
great talking 2 u Ryan top bloke, ill be back there with sum softer tyres n maybe biggr injectors so we can screw sum more boost in2 it maybe.....
http://myspacetv.com/index.cfm?fuseaction=...ideoid=41815405
Thanks mate, I was very impressed with your car, a very nice set up you have. Very jealous. Only more motivation to buy more shit for mine lol. Thanks for coming down! Good talking to ya!
Edited by Ryanrb25
hmmm, I might have it the wrong way around Ryan.
Is there more load (or brake on the rollers) at RR:020 (20kph/s) or RR:015 (15kph/s)
The higher the ramp rate the less load the rollers place on the car.
Then there's start speed, release time, end speed. Basically there is a whole lot of different combinations you can chop and change to suit the car and what sorta load you want to place on it. If a car is placed under light load but does a full power run, The true AFR reading will be false to a certain point as with power output.
hope that made sense lol.
Edited by Ryanrb25
yea sorry i didn't answer your question... rr:020 is a higher ramp rate therefore giving less load on the car...will show a slight increase in power. At the end of the day its just a figure. The dyno is purely a tuning tool. Unless your simulating near bang on road conditions then AFR's and power will not be accurate.
Edited by Ryanrb25
You were bang on the money pete. :thumbsup:
If for some reason you do need to tune with a higher ramp rate, eg. Wheel spin etc.. then a bit more care has to be taken with the tune and must be alot more concervative. So many other factors come into play.
Edited by Ryanrb25
yeah, I know Donan has changed his methods a bit over the years.
These days he tends to keep the AFR's on the lean side (around 12:1) but pulls extra timing out to compensate, up to 3 degrees (from around 20 to 17).
That's why I'm keen to get those adjustable cam gears happening at some stage so I can play with the valve timing a smidge as compensation for lost ignition timing.
One thing I like (and contemplating) about a decent set of cams is that they would dial out some compression due to the extra overlap and therefore allow me to keep my ignition timing up.
Anyone know someone selling a car for under/about $2500 with enough room for putting a wheel chair in the back ... like a wagon or R31, something with a big boot. Must be auto also :thumbsup:
just thought id post this,
fellow bmxer Matt Duncan lost his life in a car crash early this morning in Stirling North, just out of Pt Augusta.
i got the chance to ride with him a few times, and he was a shredder, always killing it at whatever he wanted to do.
RIP.
took off my brakes today. Fronts are only 2pot and rear is 1 pot. :)
Brembos have arrived tho :) awesome condition, but the bolt sizes are different :(
Just have to get some braided lines and get them slotted.
    • I sense an out of control build thread coming up lololol. That 450kW goal will end up being 600 to 700kW LOL.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
