i am getting a new bike :( wr400 01' model. should be getting it in a couple of weeks. and the hi lux is almost on the road might have to take her up the to marree for a spin then to odnadatta(spelt wrong).
cheers... michael p.s steve you are definantly a lucky man..
R888's are an awesome looking tyre..
Really curious how their stiffer sidewall but 'slightly' softer rubber (100 tread wear) hold on in a straight line when running rwd.
I'm considering the softer side walled but slightly harder (140 tread wear) R1R's for daily.
All my brakes are off now :( I thought while they are off i might get that arm that bolts onto the upper control arm and to the bottom coilover bolt in nismo silver :) Will also do lower control arms also.
Cant believe how small my standard rotors are. Still have the factory brembo pads in the brembo calapiers also.
Cant wait to get them on and head to the hills.
btw anyone know where growly is? need to get the rotors slotted.
All my brakes are off now :) I thought while they are off i might get that arm that bolts onto the upper control arm and to the bottom coilover bolt in nismo silver :spank: Will also do lower control arms also.
sure do Luke give Matt a buzz top bloke :(
>>growly custom machining<<
Still waiting for a phone call from my friend who reverses willy nilly. If i don't get a call tomorrow, ill file a police report on tuesday.
You're supposed to report accidents to the police the day it happens, regardless of whether someone calls or not
-D
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
