i am getting a new bike :( wr400 01' model. should be getting it in a couple of weeks. and the hi lux is almost on the road might have to take her up the to marree for a spin then to odnadatta(spelt wrong).
cheers... michael p.s steve you are definantly a lucky man..
R888's are an awesome looking tyre..
Really curious how their stiffer sidewall but 'slightly' softer rubber (100 tread wear) hold on in a straight line when running rwd.
I'm considering the softer side walled but slightly harder (140 tread wear) R1R's for daily.
All my brakes are off now :( I thought while they are off i might get that arm that bolts onto the upper control arm and to the bottom coilover bolt in nismo silver :) Will also do lower control arms also.
Cant believe how small my standard rotors are. Still have the factory brembo pads in the brembo calapiers also.
Cant wait to get them on and head to the hills.
btw anyone know where growly is? need to get the rotors slotted.
All my brakes are off now :) I thought while they are off i might get that arm that bolts onto the upper control arm and to the bottom coilover bolt in nismo silver :spank: Will also do lower control arms also.
sure do Luke give Matt a buzz top bloke :(
>>growly custom machining<<
Still waiting for a phone call from my friend who reverses willy nilly. If i don't get a call tomorrow, ill file a police report on tuesday.
You're supposed to report accidents to the police the day it happens, regardless of whether someone calls or not
-D
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
