Just a random question - anyone heading to the show this year? or we all agree, as always, that its a waste of money lol
Its robbery!
I'm going anyway, as Tracy's son is eager to go. Remortgaging the house so we can go. :P
Ted - "as always" implies that usually when i speak to people about the show they say its a waste of time. That was not directed at SAU in general lol. Because yes you are correct, i was not on SAU this time last year. Well done. Have a cookie.
run around the house making pshhhhh noises, and side step around corners :)
like this :P
name="allowFullScreen" value="true"></param><embed src="<A href="
type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>&">
type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>&" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350" />
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
