get these add ons craig
adblock plus
self explanatory really, blocks all those frikkin ads
download statusbar
statusbar that sits at the bottom of the browser, instead of opening a separate window
ie tab
allows u to open a page within firefox using the ie engine
smart bookmarks bar
love this one, strips the name of the url off the book mark and just leaves the logo
url fixer
fixes typos that u put in the address bar
How you can prefer IE over Firefox is beyond me Craig :P IE has to be the most horrid browser bar Safari for Windows. Well it's not computer jargon so I won't go into it but yeah, grab those extensions and you'll be sweet!
if your doing the lock bar then id advise doing the whole thing.
i did it on my old 180(same hicas system as 32), and its really not that hard. the hardest part was getting the tie rods out of the hicas rack. the rest is simple.
im trying to remember who i got my lockbar off of, hes on here, but i cant think of his username.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
