lol is that all? its pointless explaining how wide you can go if you dont understand offset. google "offset", read up, then youll understand what we are on about.
wtf? please explain HOW it is pointless? i understand offset but that has no bearing on my question, i simply asked what was the widest rim you can throw on a gtr without it rubbing, and obviously you would state the offset for that size.....i can do without the smartass-ness :P
Edited by rhys5169
well, finally going to bed after pulling the wiring out of my bike frame for the past 6hrs
don't be too noisy during breakfast you guys so I can sleep in
you get home in one go?... you didnt seem to have any trouble on south rd
got my spacers on this morning @ wheelworx....
looks tuuuufffff!
but rubbing on the front guards even though they where rolled!
so wont be lowering it any more, i hot +25mm all round, so i should have settled for 20s on the fronts
but oh well, still looks sweeeet :P
question ,
my car has way too much power for an N/A , it revs past 7000rpm without a problem .
what would be the first thing to check to see if its got stock parts in the engine ?
cause there is no way it has 140kw~
lol yeah :P it was pretty much the first time i said it out loud... and it dawned on me
was good catchin up last night mate.. the celly sounds awesome btw
haha, love it when shit like that happens :P
cheers dude, still sorta think its a bit noisy, but i love the noise it makes jsut the same.
lol, yeah it rubs major on the fronts, rears are ok........
think i gotta go back for smaller and sell off the +25s
im not too keen on the look of the fronts now either....i need other ppls opinions :P
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
