I don't think Kellie is in the mood to be helping people for a while. Perhaps give her a break and allow her to volunteer to assist. :)
kell actually spoke to me on the phone this arvo,
but thanks for your input ruby.
fishpaste~ and i were behind you, must have missed you on the side of the road (dont know how :P ) could have got a tow rope, and taken you back to your place water ski style :)
Yeah, we got WAY behind you at south rd/anzac highway intersection... can't quite weave threw cars like you can =P
We could see you up ahead, but I though you had safely turned down daws road, and we continued down south road... probably should have swapped phone #'s
ahh, thanks boys. I wanted to get home quickly while it was running fine but like I said, she broke down just outside the Tonsley Pub and I ended up rolling into Lloyd St, St Marys to avoid sitting on the main road for the next hour........I was only 1 km from home so a tow at 10kph might have been a good idea. Now I just have to go thru the threads to find a good mobile auto electrician cause I'm over working on it.
hey Pete would you be able to take a photo of your brake master cylinder on the GTR and post it up?
Just need to have a look at it before i put mine in.
Thanks Luke
OK Luke sorry it's taken so long but here goes.....the blue bracket is the support for anti flex.
EDIT: Thanks Carl
had a dinner party last nite at my place, it was great.
we supplied pizza bases, cheese, shredded ham sauces etc, and then got ppl to bring along other ingredients... easilly fed 19 ppl, and had some good times
had all sorts of gourmet stuff... the best pizza i made had satay sauce, chicken, onion, camenbert, and mango :)
Hi everyone, i was just browsing as usual.. and came across this thread that i thought might help you prevent theft in case you missed it.
http://www.skylinesaustralia.com/forums/An...ft-t231396.html
scroll down to the posts "waza" makes and there is a lock that prevents people from shifting gears when the car is unattended to.
I thought this might be useful for everyone that is paranoid about their cars being stolen.
Edited by TS-R34
just sold 2 of my 25mm spacers :)
will be going to wheel worx tomoz to pick some more up
not sure whether to go 15 or 20 :P
measure the point of the tyre that stands out the most to the top of the gaurd. will give you the best idea if you didnt want to drive the car to them.
or just do what i do and ask joe to let you test fit or ask for advise. dont want to end up were you were before :P
yeah, im gonna take the 25s off, and drive it down to wheelworx on saturday now,
ill ask for a test fit on the 15,
i want them to look good, but not rub, i want the best of both worlds :)
should have called you to meet up for entry forms today kye.... i was down at my auntys holiday house in aldinga
:P and i was home most of the day too. its sitting in the boot of my car so ill hook you up before friday.
flat tyre and no tyre shops open on a sunday is gayness. i dont trust those space savers!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
    • With ordering the belt, you're doing water pump and the idler and tensioner at the same time too yes?
    • This is just a dumb way of keeping the wastegate closed to make more boost. Undo it and either follow the factory setup or redo it properly. Manual boost controllers just use a spring preload to determine when to close in response to boost pressure so it no longer vents to atmosphere.
