he tried pulling the ill show you my new fuse tomoro, just dont defect me talk, didnt work, he would have got defected and had to spend soooo much money from the look of the mods! sucks that it happens to skylines, or imports, but no tail lights is f*king stupid if you ask me
+10 for playstations customer service
-9 for there faulty disk drive :(
was just about to play some cod4 then my screen went black and my ps3 was making a wierd noise, so i turned it off then on and it wasnt reading disks, rang around and apparently it is a "common" problem with them, so called sony and its already on its way to get fixed
10 business days tho :(
my ps3 broke and did the same thing as yours.
rang sony, they said they will replace the ps3 with a new one in 10 BUSINESS DAYS
nearly 3 MONTHS LATER, i got my new ps3.
and after i asked them to put my old HDD in the new one so i can have all my saved games, they didnt and i had to start over on everything.
sony 'sounded' like they were going to be awsome about it all but it just took way to long to get my new one, i was getting ps3 withdrawles!!!
Edited by Import S13
Yeah they're alright I spose...
HAHAHAHAHAH yeah I miss my old one so bad. I was hoping Aussie would take it out for some skids but so far I think I'm still the only bloke whose drifted one on Mallala, maybe even the only bloke to drive a 100 on there ever :bunny:
LOL @ your thread on jzx100.com too, funny how things change, now I'm the dirty Nissan driver :(
yeah love the 100's gotta be modded tho IMO, stock ones are a little boring to drive.
>>> here <<< is the link to that thread :(
I found mine was a dream to drive stock, so goddam smooth and cruisey (if you like that sorta thing :()
It took me about a month or 2 before I was craving the coilovers to go back in and straight pipes to be fitted :(
My next one will be auto and cruisey, I'm over shitbox cars.
stupid GTT blood test, i ended up throwing up after i had that sugar drink.
probably drank it too fast LOL.
they kept telling me i'll just feel a little sting and i'm like "don't tell me that" lol
but yaaaaaay i can eat again :D
so are you a skyline or not :( :(
steve, how long is the group buy gonna be open for?
i have some pretty big things on my plate atm,
but i dont wanna miss out
um you haven't read 4 WEEKS
lole $134 for rego for me :bunny: low income earner and single parent :P
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
