if no-one has posted about this, they're the guys that run the inspection stations out on the side of the highways, plus they also have rights to pull over and issue defects to heavy vehicles and taxis
these pricks were running round town one night, they'd finish with one cab, bolt round the corner, throw on the purple lights and do another one :)
and on another note, my internet speed :P - bigpond cable internet (same cable as foxtel uses :) )
Too slow
321636669.pngFTW. A bit slow because the wife and kids computers were playing games when I did this.
Edited by 4door_Sleeper
ye man it keeps coming up with an error when i try n sign in :P
i clicked the trouble shoot and it fixed it through its steps try that 1.
on another random topic :) does anyone know of anyone thats had a non convertable car turned into a convertable or workshops that do it?
i heard its easy enough if you gota steel chassis but is that the only reasonable way?
to below yeah that is pretty low but i only got 5827. its quick enough for sau purposes :) learn some patience people the porn will download eventually
Edited by Inline 6
hey just wondering does anyone know if anyone in adelaide does RB20 ecu remaps??
been thinkin bout gettin one when i get my 32 back
Mike Dale from Road & Track can do any remap to any nissan ECU as well as a safe and reliable tune (or if you specify it, a dangerous hardcore performance tune). give them a call. info is in my sig.
+1 from a happy customer...I'll be getting a stock 32gtr ecu modded once I get the turbos and supporting mods... and best thing yet, I'll still be able to do data logging/live telemetry/consult diagnostics/ecu map fine tuning with a nice conzult cable/software kit :) Got the EEE, wired it into the glovebox... just need the conzult kit. +2 for solid state hdds and their tolerance to vibration and gforces :P
-D
    • Thanks man, I appreciate that. I'll keep it in mind going forward, important to know.
    • I strongly recommend anyone playing with cars chasing anything electric, get a basic understanding of using a DMM, and about 12V DC systems. They're REALLY easy, you only need to know V=IR and how to apply it, and you can work out what your readings should be doing. For a simple check on a light bulb, you're looking for 12V at the positive to the light, a near zero resistance to ground, and then for a small resistance across the globe when unplugged. If one of those values isn't right, you won't get what you need. Now if they're all okay,and you then plug the light in, and it still won't work, you now do a voltage check across the globe positive to negative. It should effectively read full battery voltage. If it's not, especially if it's quite low, the age old V=IR starts to be able to be thought about, you now know though, for the current flowing, there isn't much voltage for the given resistance, but the rest of that V has to be dropping somewhere else. So now do a voltage check from ground of globe, to ground of car, then do voltage check from positive of battery, to positive of the light connector. Things like a high resistance in a wire/join will start to "steal" voltage on you. So now step back through which ever wire, until you find the voltage drop is non existent, you're now before what ever is steal your voltage for example.   There's plenty of YouTube videos, but really worth understanding some V=IR, and doing some even theoretical numbers to start to understand it. Then you'll know what the DMM is telling you.
    • Is Jackie home by Friday?
