Anyone in the hills area keen for a drive later? Kinda keen to go out for a run, been a while.
I was thinking about it there's an INFMS cruise on there way out to Lobethal at the moment i was thinking about catching up with them. What area are you in? I'm in Campbelltown.
wat size xd9 should i get??
18x9 +20 all round or F18x8 +35 or +28 R18x9 +20
i have no idea on offset!
18 x 9 +20 all round.
If you want to run 8s on the front you could go a lot lower offset, I've got 16 x 8 +0 on mine and they sit wicked.
*teh edits* I live 10 mins past Mt Barker, and I just got a call from my mate so I'm gonna head out in about half hour for a lil drive. If anyone wants to head my way and meet up somewhere nearish Barker could make a few car cruise out of it :laugh:
Edited by AndrewJZX100
they will sit on a 32 alright?
how much will they stick out?
Mine has hammered guards and ran a 225 on the back, sat mint as. The front has Nismo negative camber top arms so I've got a fair bit of clearance (ran 235s on the front with pretty much untouched guards and they only scraped on massive bumps when puching hard mid corner)
If you don't have camber arms, run a 17 on the front with a 215/45 and roll the guards properly and you shouldn't have any dramas. Will look fking hot too :laugh:
*edits* re-reading your question, they will stick out a bit. Rears will be sorta flush with camber, fronts ditto but if you don't have any camber on the front they'll be out by a few cm at least.
yeh might go with the 18x9 +20 allround, maybe a +28 ish on the front to keep it in abit!
That's probably your best option, slighty higher front offset. For reference, this is a 17 x 9 +20 with a 225/45 and 3ish degrees of camber. Flush city :laugh:
Ok people keen on Meeting up to go to Mt barker SMS me where you live and your user name.
Dale
0439848276
Edit, and can you send me your number andrew?.
P.S. can a mod delete my number tomorrow, thanks
Edited by D_Stirls
He sounds like a real dick amanda
ha yeah it's amazing how fast some people change when they find out they got some1 pregnant.
i don't know why i bother with him though, trying to get things sorted out so were atleast on
better terms but yeah he's barely interested in doing that.
it's exhausting lol and i barely have any energy
Its a fairly big thing for a bloke to be having a child. It freaks them out quite a bit especially if they are young. He will be up and down.
Maybe start taking another approach.
Take a step back, don't be angry, give him some space/time without harassment once he sees the baby his instinct should take over. Hopefully. :S
imo, he should be a man from the start and take his responsibility....whether theyre a couple or not, doesnt make a
difference, it is still his child!
i hate pricks like that.
yes you can't expect to wave your wang around and there'll be no consenquences!
sweet... looks nuts!
anyone got 18x9 +20 that i can test fit before habding over the cash??
cheers
You should PM the user 'ABU' about the offset and sizes he had on his GTS-t
I don't know offset but I think it was 18x9.5 and 18x10 with slightly pumped and rolled guards.
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
