this clearly has the PCOTY-1 plates too :D forgot to mention that LOL
ah yes, well then it is definitely a pic of me on the drag strip :( - ah those were the good old days!
I remember the PCOTY s15 driving around a few years back. and watchin it at AIR.
when they had runs on sundays ? or wednesdays nights ? when anyone could come down and have a run.
well then you were watching me :D
Was always good fun since MattR and Busky2k would take out their S14s and always try to beat me (but never did). Then there were the hardcore Commo boys in their VRs and crap getting absolutely owned by myself and every other import there. I was even demolishing brand new SS Commos and Senators and the like (before the days of Donnon's twin turbo setups) who thought they were the bees knees.
We even had once a private SAU drag strip day with a couple of other small clubs, and had Munro and Keir run their 9 second GTRs. I remember I blew something up on the S15 and put it in the garage, so MattR and I went up in the commentators box and got on the bourbon cans .... was an interesting day of commentating, that is for sure!
Well said. He didn't target anyone in particular, so its ok imho. And I agree 100% with the suicide remark. Point is, if we're going to be sanitizing everything and leaving this forum to only car talk, then we could say that any talk about religion, politics or pregnancy is totally off limit, cause quite frankly I come here for the cars, no other reason. Could care less about anyones personal views on those aforementioned touchy subjects, don't care about religion, or children, or any such thing, and hence I just ignore the things I don't agree with/don't care about. I'm not about to start a fight with anyone, but if someones posting a picture that is clearly meant to be humorous, and you don't think is appropriate, then thats your own personal prerogative. For every one person who takes offence, theres 10 more that are having a belly laugh. If someone gets offended with me or anyone else, PM them directly and we'll either apologise or argue our point. Otherwise we'll be policing stupid arguments and wasting a lot of breath.
Political correctness. Makes me f'ing sick.
-D
Quoted for truth.
yeah im pretty sure if had stockies when it was running ? or something similar.
and If i remember correct there was usually a pretty decent burnout to warmup
those were the days. A nice night watching some nice street cars, having a few drinks or participating.
getting my hub studs and coilpack cover bolts (maybe) through Nissan! woo thanks Kel
in other news, the AUD has crashed against the USD
and
1 AUD = 81.5049 JPY
wont be getting any japland stuff any time soon, looks like Luke is gonna have a quiet next few weeks haha
hey all was working ner the village today when i heard what sounded like a skyline valve bouncing thru the gears, burning a shit load a tread and f**king the engine pretty hardcore just wondered if anyone else heard / saw it to? happened around 1.10 this arvo. im thinking it was stolen
and
1 AUD = 81.5049 JPY
will kell wipe your bum aswell? seems she does alot for you guys!
can only guess two i think....
my 33 and nenes'/bens stag?????
there is also mine and damos car in there.
What prize do i win?
and also jacks 33
Edited by Luke_ENR34
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
