if its michael doing it, you will be sweet :P
thats the next big shop imho
aussie dyno = top work.
its actually Peter that does it Craig, Michael just sits in the passenger seat and holds the pfc controller...lol
+1 for Aussie dyno
well i think im gonna run
17x9.5+17 front
18x10+18 rears
or stick to the 18x9 +20 fronts!?
good choice my friend....will be good!
+1 for Aussie dyno
Michael is actually tuning the car dan, pete is just running the car up.
Edited by Ryanrb25
+1 for Aussie dyno
where are they located??? i reckon i need to switch workshops as the current one i take my 32 is not that crash hot and now thinking of things they have done im getting pissed off lol
would take it to boostworx but it is too far out the way for me.
cheers
i was in melb from friday and got back tonight :banana:
just HAD to take the 33 out for a drive after leaving it sit for 3 days :angry:
so glad im home now , got so bored at grandparents house :bunny:
we got into Melbourne at hmm 10pm (Vic time).
yeah we left our car parked at the Crown Casino the whole time, too much walking
back and forth, but it was great.
on the way back from parking the car me and my mum walked past 2 guys, 1 said
"what do i do?" and the other guy said "well what you do is ask how they are and how there
night is"
i friggin pissed myself laughing coz well practicing what to say to a girl to pick her up :nyaanyaa:
i miss Melbourne :rant:, i didn't get homesick so yay
well got all the turbo and all piing etc put back on, gave it a quick start
to make sure it still runs :banana:
only thing i noticed is a big amount of smoke :nyaanyaa:
hope its just cos it hasnt been started in ages.....
gotta tighten up all the cooler pipes and final bits ' n peieces, add some coolant
and it shouls be done...... i hope.
all this for one bloody gasket.
Has anyone done pads on the rear with only 2 of the halves having metal tangs in the corner of the pad while the other 2 halves don't?
Anyone knows if it matters whether the pad with the tang goes on the inside or outside of the rotor?
Sample pic only, off a different make of vehicle;
ahh good stuff Luke thanks....I better get back out there and finish off now.
Doing the rear coilovers tonight as well and the fronts tomorrow hopefully.....will post up pics later.
EDIT: Just looked at your pic Luke, that looks more like an anti-squeal shim that goes across the back of the pad......is that what you were referring to or were you talking about the small tang on the bottom corner of the pad?
The tab is just the wear indicator. As 4 piston calipers should wear evenly (equal pressure on both sides and no sliding pins that lock up) it doesn't really matter where it goes.
It's the thing that squeals so you know that your pads are close to worn out before they actually are and you have metal to metal contact
Edited by D_Stirls
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
