they are 17x 8 +17 fronts and 17x 9.5 +24 rear :dry:
Are they Brentons old meshies? Specs sound similar. Look like they sit pretty mint, full body shots needed (in daylight) though :kiss:
i just went down the street to get drinks for tomorrow, and had a guy come up and introduce himself to me.
it was none other then Mr Senwill himself, he liked my car!(and i liked his, brand new twin turbo range rover, he also has a brand new single turbo petrol one.. :P )
had a chat with him about a bit of stuff, then he gave me a Drift Central 3 dvd! put a smile on my face to meet someone like that in a little town like this, AND he was the nicest dude you will ever meet!
stoked!
Random as
Edited by AndrewJZX100
Well a massive thanks to Ryan, Aussie Dyno and Turbosmart for seeing my car pull 198.1 rwkw today :( apparently im a bashed cat away from 220. ill post up my dyno sheet once i get my camera working. Highly recommend Aussie Dyno, made very very sure i was running 100% safe while still squeezing power out of it!
oh yeah, the hoodies wont be at vili's tonight, due top lack of interest combined with my family down from interstate. next pick up will be my cruise on monday
Edited by Damo_R34
hey mods... can we get aussie dyno into the workshop listings?
Aussie Dyno Mufflers & Brakes Pty Ltd
(08) 8340 0584
373 Port Rd
Hindmarsh SA 5007
exhausts, tuning, dyno (4wd), general mechanics.
cheers
hey guys, after an opinion!
under boost, my 25 is making a high pitched squeel - from area around the turbo; i'm thinking it may be exhaust/manifold leakage.
I havent really investigated by removing bits and pieces under the bonnet yet, - i might take the heat shield off the std turbo tomorrow and have a geeze for any signs of soot and black crap.
Anyone had this issue before?
yes mate i had this exact same problem about a month ago, gasket between turbo and manifold mate...
ahh, so it very well may be the culprit! I asked my usual mechanic, and he guessed that a gasket would probably be the cause.
so basically, you got to remove exhaust front pipe and dump, remove turbo, replace gasket + new studs yeah?
doesnt sound like much, but it'd be a pretty legnthy job hey Ryan?
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
