i need rubber tyres, the plastic ones dont grip, and if you turn it just spins lol. guess i need to work on my control
has it got a rear locked diff, If not liquid nails will do :)
Can you adjust your camber and toe, If so try 2deg frount and back camber and try just half throttle at first
Not his fault. Car infront slammed on brakes, so did dad, guy in the 4WD with the roo bumper behind dad, was looking to the left, then when he looked to the front he slammed on his brakes, but obviously not quick enough.
Apparently theres two nice long tyre marks on the road out the front of the Aussie pizza shop on marion road lol.
dunno what it stands for, but they have a cruise 2nd sat of every month, always have a big turnout!
i wanna cruise sat night :/
i aint stayin home with a house full of chicks, that dunno when to keep there voices down!
Anyone wants 1 of those yokomos got 1 here i want to get rid of got in to nitros its got the half platic half rubber tires abnd a battery charger for the car battery. Its got a white s15 with the big drift wing exhaust and some rays look wheels
Just got off the phone with the old owners of my house, they will be moving out at the end of the month :/ and i'll be moving in. So putting the turbo's on the skyline will have to be put on hold for now, but still hope to have them on before the end of the year.
spent the last 3 or so hours washing, clay barring, and putting a few coats of wax on the celsior, still needs a polish and a buff, but f**k, paint looks like glass, dont think it was even that clean when it rolled off the showroom floor.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
