i need rubber tyres, the plastic ones dont grip, and if you turn it just spins lol. guess i need to work on my control
has it got a rear locked diff, If not liquid nails will do :)
Can you adjust your camber and toe, If so try 2deg frount and back camber and try just half throttle at first
Not his fault. Car infront slammed on brakes, so did dad, guy in the 4WD with the roo bumper behind dad, was looking to the left, then when he looked to the front he slammed on his brakes, but obviously not quick enough.
Apparently theres two nice long tyre marks on the road out the front of the Aussie pizza shop on marion road lol.
dunno what it stands for, but they have a cruise 2nd sat of every month, always have a big turnout!
i wanna cruise sat night :/
i aint stayin home with a house full of chicks, that dunno when to keep there voices down!
Anyone wants 1 of those yokomos got 1 here i want to get rid of got in to nitros its got the half platic half rubber tires abnd a battery charger for the car battery. Its got a white s15 with the big drift wing exhaust and some rays look wheels
Just got off the phone with the old owners of my house, they will be moving out at the end of the month :/ and i'll be moving in. So putting the turbo's on the skyline will have to be put on hold for now, but still hope to have them on before the end of the year.
spent the last 3 or so hours washing, clay barring, and putting a few coats of wax on the celsior, still needs a polish and a buff, but f**k, paint looks like glass, dont think it was even that clean when it rolled off the showroom floor.
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
