haha, boy did the main page get a clean up once Andrew logged on
what i miss pc has been stuffed so havnt been on, just at uni now :(
I might have cleaned up a bit :) .... yes the number of useless/repost/wrong section threads seems to be increasing .... might be time for me to sticky another rant ;)
i wouldnt recommend going 6x9's in a skyline unless u plan on not running a sub. 6.5ichs will give u alot clearer sound and maybe like one sub in the boot will do. Depends what u like.
thats why ive got 6x9s in the back and 6" in the doors
plenty bass for what i want , i had a 5 amp 3 sub system in my commodore , im over it haha
heres a quick snap:
might be able to mount them vertically/diagonally or something...
i've got fusion 6.5"s under the stocko covers but one of em is blown and vibrates/sounds like shite. been meaning to replace em for years
yeah you could easily work around that man ,
if your going to make a new parcel shelf then youd have to use thin wood and use the current one as a template for the strut brace
agreed, subs FTL. 6x9s + a good set of 6 inches in the door is all you need for a nice clear sound.
im gonna amp my speakers when ive got the money
all my speakers are 300w each so will sound better with an amp imo
im sure you could work around it couldnt you ?
heres a quick snap:
I might have cleaned up a bit ;) .... yes the number of useless/repost/wrong section threads seems to be increasing .... might be time for me to sticky another rant :(
yep, go for a sticky rant i rkn. I mean, im a whore, i admit that, but i always shoot my questions through the wasteland, well most of the time.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
