cool, cheers steve. Hope i just need new spark plugs.
Have u got the steering wheel on yet?
Start with the plugs.
There is no benefit in going to Spitfire coil packs if your standard ones are OK - many claim the Nissan coil packs are better anyway, just way too expensive.
Make sure you clean the coil packs prior to re-installing, and you can use areldite (sp?) to fix some cracks.
is it scandinavian flick entry commonly used in drifting?
yeah the drifters use it alot but i only use when the car is underpowered and can't spin the wheels with just the throttle! otherwise just use the handbrake
how do u clean the coilpacks?
Carefully
I use Electrolube and a clean tooth brush.
You are trying to remove any carbon from the cracks as the electricity will travel along this. Clean will increase the resistance and make it harder to arc across.
call me stupid dave,
what what is your username derived from?
or something far more complex that my not yet mature brain is in-capable of recognising?
dont worry craig, i recently owned up to dave that it only twigged to me recently what it meant.
only once i said it did it dawn on me :)
drying your car is the most important part i have found... especially as i have a black car.
a good chamois and a microfibre cloth is what i use to get mine dry (i move it into the shed once i have washed her so the water does not evaporate)
yeah , i might wash it and then roll it under cover and chamois it , dont have a microfibre cloth though :D
or i could use this waterless car wash i have , s**t's magical :)
my housemates dog scratched my car :P
he is so bored (choc lab). we all play with him and walk him etc, but he still needs moar.
he tore apart a thing that had a massive piece of wire in it and it has whipped against the passenger side of the car *sigh*
    • This. A 3d wheel alignment is like $120...just take it to the shop. Since theres probably multiple adjustments that need to be made after changing something. Mine has front/rear lower arms, traction rods, tension rods, camber arms, toe arms, front upper arms, hicas kit, sway bars and coilovers. I measure from the edge of the bolt holes on the originals and set the same length on all the adjustable stuff to dial it as close as I could to OEM. Took it straight for alignment; it didnt feel right at all...after alignment, it feels perfect. Similarly i've just changed the springs on another car; and I still needed multiple adjustments to bring it back in spec.
    • A full Veilside kitted JZA80 Supra in Meriken park in Kobe city a few weeks back
    • Its a well known brand in New Zealand; its a rebrand of the Rhino RAV3.  I don't know what the wiring difference *is* between the rev.1 (installed about 15 years ago) and rev.2; but as you say I would think its reasonable that it uses the same immobiliser relay circuits. I had a look but couldnt see a similar harness; but didnt move things around since I didnt want to mess with it   It was one of AVS well known Authorised Installers; I spoke to AVS themselves about it but theyre unsure hence seeking advice more so from the skyline community who are more familiar with the actual car and its wiring. Im in Auckland; but the installer is on the other side of the city so hes very reluctant to come back to even look at it to confirm something isnt connected into the wrong wire.  I dont want to drop the name since they *did* do a really good job for the most part. Everything is very tidy and he fully replaced all the alarm wiring, all the sensors, the wiring to the door motors, installed a switch which was never installed in the first place...really happy with the alarm install itself..just not this one issue. We all make mistakes, if it is the alarm, I just want my fuel pump getting proper switched, fused, power as it was; without having to shell out for an auto electrician to switch a wire and tell me it was the alarm.
    • Even with the piston at TDC there was room for it to drop, but I don't think it can drop fully into the cylinder, the problem you have is that you need something pushing against the valve to hold it up so you have enough room to put the new stem seal on and the spring etc.  I used compressed air only because putting rope in the cylinder seemed a bit risky to me, I know people have done it countless times before like this. Overall it's a pain in the ass job. Honestly you'd probably be better off taking the head off because the risk of dropping something in the engine and the finicky-ness of it all is very stressful. If you are going to attempt it though i 10000% recommend a 36050 valve spring/keeper tool. I had both the traditional lever type and after doing 1 cylinder it was absolute pain to get those valve keepers in place, even with 2 people. That 36050 is amazing, you do have to push hard to get them in place but it works perfectly almost every time. Back to my actual issue I think my engine is just tired and old and the rings have gone bad. The comp numbers (cold, no oil) were: Cyl 1 -129psi Cyl 2 - 133psi Cyl 3 - 138psi Cyl 4 - 137psi Cyl 5 - 157psi Cyl 6 - 142psi   Cylinder 5 and 6 having the most carbon on them.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
