on the way home just now some magna was trying to race me :)
i think i need vroooom chhhhhhhhhh now
i was going out earlier and some vl commodore kept on coming alongside me and revving his engine, took a quick glance aside and saw the passenger had a missing tooth at the front. came to the lights and they were trash talking etc like all stereotypical commodore drivers do.
Shame my car has some exterior work that needs done, else my car would have looked the part far more than it does :no:.
on that note, i don't suppose anyone could give some hints for the following.
Front suspension is sagging, needs to be swapped out, does anyone know of a decent price for some decent front suspension (i recently bought springs off another member here, made no difference so it's more than likely the suspension.
and as a direct result of the suspension, my front bumper has taken some damage. does anyone know a place that would be able to repair it and respray it? also needs a better fit as the previous owner tended to do jobs in halves :D
also a set of fairly plain 17"/18" rims +tyres? i've heard tyrepower blackwood are pretty good, anyone else have any suggestions? (i live south of town)
Ive gotta say the only recent competition ive had was some kawasaki motorbike and even that I could keep up with until he got his front wheel off the ground and then he jetted off.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
