You start to get more philosophical as you get older, yesterday i realised that getting married is very much like going to a restaurant with friends.
You order what you want, then when you see what the other person has, you wish you had ordered that.
well well well the school kids are back in town
and woman wear white because they are pure and boys wear black cause they aren't
and most kitchen appliances these days are stainless steel you goobers :bunny:
thats if not the funniest thing you have said ever :bunny::(
are u implying that black people are impure <:|
on the other hand
all i need is a woman coated in stainless steel, then I got myself a perfectly color co-ordinated designer label kitchen. hell yeah. that'll impress the chi... er... well... it'll impress me. maybe I can put some spinning rims over her metallic bosoms
-D
what the hell is with this crap
http://i33.tinypic.com/sq0eh4.jpg
ever since my mate browsed sau on my pc its coming up and its really annoying the shit out of me :bunny:
In the top Right hand corner of the thread click the "options" tab then click "switch to standard"
-D
I think they have gone to stainless simply because its more expensive.
My son asked me the other day, "Dad, how much does it cost to get married?"
I had to be honest and tell him, "I don't know son, I'm still paying."
By the way, do you know the substance that has the power to parallyse a woman from the waist down - for life?
Its wedding cake.
The thing I find confusing with women is that even when you do what they ask you you still end up in trouble. I once had a girlfriend told me I should be more affectionate. So I went out and got two other girlfriends - she hasent spoken to me since :bunny:
Its wedding cake.
f***in LOL !
thought would give you guys a look forthose interested, small vid of me, matty and another mate at mallala saturday just gone for drift prac. Highlights, matty cleans up the tyre stack at turn 1 an i do an awesome parking job lol.
Enjoy.
http://au.youtube.com/watch?v=0iQqJGR-zYw
bit dear wait till next year and get one local for $150k
not the way the $AU is going Steve................you may have to add another $50K to that price by then..............not to mention the luxury tax has gone from 25% to 33% now, thanks to Rudd
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
