for sure Dan; you ignore just about any price you'd see on the piece of paper hanging in the window of a car at a car yard.
jeez i remember the price listed in the window of my white 33 (in my avatar) when i bought it from a yard back in the day... we knocked quite a sum of that price off compared to what i paid :)
guys need ya help palease :)
oka so went to go see my car today down at premier paint n panel n its finally coming together..yay..but a lil problem has occured..they have gotten my car to start and god does it sound good to finally here it again lol but now my hicas light is on and the steering is heavy as...ive had the hicas light on before but the steering wasnt affected..all i did was change the power steering fluid and it went away.
the guy said that had to disconnect some hoses around the power steering pump to do some work so im hoping that it just needs a top up of some fluid
would i be right??? or is it something else??
there hoping to have my car finished by this friday....cant wait :)
ur help will be appreciated.thanks
you will prob find that due to the car sitting around for so long, all the fluid has drained from the lines, and dried up.
give it another change, and see how you go :)
good to hear its nearly done...
This might not be the issue, but my Hicas light was on a while back and the steering was really heavy. It turned out to be a loose battery terminal (no bullshit). New terminal and the issue went away.
Check that, but more than likely it won't be that.
But check the power steering fluid and the hose connections.
Last night after work i decided to go to town on my dump pipes with a die grinder. Where the 2 pipes join together i ground out the hole to perfectly match the shape of the smaller pipe, spent about 1 hour on them as they are stainless so had to try and keep the metal cool. It should help to improve exhaust flow a fair bit :wacko:
hmm, how are b pillars stuck on? (The black plastic that is between the front and rear side windows) just glue?
On 33's theres a couple of lugs behind there, just pull the bottom out gently until it unclips (you may need a flathead) then lift it upwards. I've never tried doing it on a 34 so it might be different.
went and had my car remapped at turbo tune today and i gained 34 rwkw out of it
first run pulled 88.1 rwkw with a blocked fuel filter and fooked fuel pump..so replaced both of them and it pulled 111.2 rwkw
then after the remap it pulled 122.2rwkw..
im pretty happy with it considering the only mods are HD clutch, 2.5" full exhaust system with race cat and K&N panel filter
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
