for sure Dan; you ignore just about any price you'd see on the piece of paper hanging in the window of a car at a car yard.
jeez i remember the price listed in the window of my white 33 (in my avatar) when i bought it from a yard back in the day... we knocked quite a sum of that price off compared to what i paid :)
guys need ya help palease :)
oka so went to go see my car today down at premier paint n panel n its finally coming together..yay..but a lil problem has occured..they have gotten my car to start and god does it sound good to finally here it again lol but now my hicas light is on and the steering is heavy as...ive had the hicas light on before but the steering wasnt affected..all i did was change the power steering fluid and it went away.
the guy said that had to disconnect some hoses around the power steering pump to do some work so im hoping that it just needs a top up of some fluid
would i be right??? or is it something else??
there hoping to have my car finished by this friday....cant wait :)
ur help will be appreciated.thanks
you will prob find that due to the car sitting around for so long, all the fluid has drained from the lines, and dried up.
give it another change, and see how you go :)
good to hear its nearly done...
This might not be the issue, but my Hicas light was on a while back and the steering was really heavy. It turned out to be a loose battery terminal (no bullshit). New terminal and the issue went away.
Check that, but more than likely it won't be that.
But check the power steering fluid and the hose connections.
Last night after work i decided to go to town on my dump pipes with a die grinder. Where the 2 pipes join together i ground out the hole to perfectly match the shape of the smaller pipe, spent about 1 hour on them as they are stainless so had to try and keep the metal cool. It should help to improve exhaust flow a fair bit :wacko:
hmm, how are b pillars stuck on? (The black plastic that is between the front and rear side windows) just glue?
On 33's theres a couple of lugs behind there, just pull the bottom out gently until it unclips (you may need a flathead) then lift it upwards. I've never tried doing it on a 34 so it might be different.
went and had my car remapped at turbo tune today and i gained 34 rwkw out of it
first run pulled 88.1 rwkw with a blocked fuel filter and fooked fuel pump..so replaced both of them and it pulled 111.2 rwkw
then after the remap it pulled 122.2rwkw..
im pretty happy with it considering the only mods are HD clutch, 2.5" full exhaust system with race cat and K&N panel filter
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
