I have 19's on my 33 and they really dont look that big at all. on a 32, they would look huge... also the difference in price of rubber between 18's and 19's is bugger all.... Im considering selling mine at the moment too if your interested :cheers:
+1 had 10s on my 33, good size considering the size of the car.
but yeah, 18s with dish also suit.......
ps, nice stag!
Edited by craig R33
