Bah i like the new model with the 1078cc engine.
ummmm ruby has the first bike in the pic very fast and a comfortable ride for passengers i love being on his bike. ask roo about it if you want one :)
I have a 4ft aquarium, i have about 8 Kribensis Chiclids, 2 clown loaches, 2 Bolivian Butterflys, 2 glass catfish, 1 bristlenose catfish, 2 mollies, 4 blue tetra, 4 red tetras, 3 guppies.
I also have a pretty cool looking Red Horseface... but I keep that in my parents aquarium so it wont eat my Tetras.
Im also going to buy a Ghost Knife soon as they are pretty cool fish.
What aquarium shops seem to have the largets range of fish in adelaide?
just a quick one for all that are thinking of a group buy on back sack and crack:
1. Do not shave the treatment area for at least 10 to 14 days before you wax. If you do, the procedure hurts more; a lot more. Also, it’s not quite as effective as when the hairs are longer.
2. Pre-medicate about an hour before the procedure. No matter how macho you are, take your chosen pain reliever about an hour before your appointment.
For me, pre-op alone for a Brazilian wax involves taking at least three Advil’s, multiple deep breaths, experiencing several aborted panic attacks as well as mental exercises to distance myself from my body to deal with the pain and the utter shame that I will surely feel as the waxist molds me into certain, inhuman positions. I don’t do yoga, so my ankles do not hook behind my ears all that easily.
3. Shower and clean your entire body thoroughly before the appointment. It’s only fair. You will see what I mean as this service involves a certain amount of nudity and some very embarrassing positions.
4. Make sure to seek the services of a licensed esthetician who is trained in the Brazilian technique and regularly treats men. Calling first is a good idea.
5. Use a good body scrub between wax treatments to discourage in-grown hairs such as DERMAdoctor KP Duty Dermatologist Body Scrub with Chemical + Physical Medi-Exfoliation, Peter Thomas Roth AHA/BHA Face & Body Polish, California North Gelskin Scrub and Neova Body Smoother.
6. Apply No Bump Skin Treatment after the procedure to the newly hairless area to stave off ingrown hairs which form when hairs, growing back after waxing, fail to grow out of the skin. The hairs curl over inside the follicles under the skin and create an unsightly "bump" that can be painful, if it becomes infected.
7. If a burn occurs, apply Vaseline or Polysporin Ointment or Neova After Shave Therapy to soothe the affected area.
8. You also may need some ibuprofen or aspirin after the procedure if your muscles are sore from the pretzel-like positions your body was molded into by your waxist/torturer.
9. If errant hairs appear, be ready to tweeze. You may need to purchase your own tweezer like Tweezerman Professional Beauty and Body Waxing Tweezer as your partner probably won’t want to share theirs. Can you really blame them?
10. It’s not over just because it’s over. As we women know, waxing may last longer than shaving – and I stress may – but that doesn’t mean you are free and clear of your hair-removal responsibilities for extended periods of time. Men too will probably need to wax every four to six weeks. So you may want to consider making your next appointment before you check out or else you will surely lose your nerve.
im doin alrite
had a trial fit of some new wheels for the patrol. Glad i didnt go from what pics look like, as the ones id chosen didnt look any good (troy bought me one across from sydney)
24102008168.jpg <---- that be the rim
Image122.jpg <---- that be it fitted
nowhere near enough dish for my liking
BRO !
im doin alrite
catalina aquarium, parafield gardens they got huge ghost knifes.. and alot of fishes
yeah, i know its a bit of work, but they look amazing when looked after....
i didnt realize there was THAT much work though.....
def going tropical though
atm i have 4 goldfish each around 20cm long and fat as all hell (120 ea) and various other cold water colours
but im bored of them, too easy to look after, and not enough variation
if you keen to sell the corner unit, let me know,
Craig the predator fish are the best and funnest ones to keep (the 1's that feed on goldfish)
ive kept all sorts, had a big 6foot australian native freshwater predator tank consisting of MURRAY COD, YELLOWFIN, PERCH, SNAKE HEAD GUDGEON, SLEEPY COD, TANTANUS CATFISH and they all grow BIG, when it came to feeding time it was a BIG frenzy all you could see was gold scales haha
but the best fish 2 keep are SARATOGA (AUS VERSION OF AROWANA) and BARRAMUNDI
BARRAMUNDI have lightning response when it comes to feeding, had 4 foot long ones in the same tank
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
