Sorry mitch, but I can't see anyone paying $12k for a non-turbo. Like steve said, maybe $9k is closer to the mark.
yeah no joke , gonna wait and see what happens with my financial today , if it goes according to plan ill drop the price in order to sell asap
plus im gonna speak to my dad when he lands in Melbourne and see what he takes on it .
im trying to get my mate who just bought a skyline yesterday who cant handle the power and wants to return it to stock standard to consider trade plus cash his way
as all he is wanting is a skyline he can daily to work and back and im sure mines perfect for him , plus he isnt a car person .
doesnt know what a hicas lock bar is or what coilovers are so...
time will tell :P
Swap + $ with your mate seems like the best way to go - convince him of this. Maybe swap cars for a day or two to see if he likes the idea? Saves you the hassle of having to sell & buy again.
yeah thats what im thinking , the only thing is he is fair sketchy on manual and i got to drive his car around all day yesterday although it does have a TODA Racing clutch which is really hard compared to a normal
clutch so im pretty sure he would be fine in my car as my clutch is light as in comparison , but yeah im gonna suggest that to him today because he likes the r33 but he wants to return the one he got to stock ,
and last night he called me saying he regretted buying the car he did as it had too much power...
hopefully he is willing to trade
GL with the sale mitch, good car for someone who already has an engine they wanna drop in, your paintwork is immaculate.
cheers damo !
even all of my mates agree with my cars body and paint and how immaculate it is :P
well, Ive been quoted petrol money change out of 2grand to fit and tune the following:
Cometic intake manifold gasket
Cometic intake collector gasket
Cometic exhaust gasket
Cometic Head gasket 1.2mm x 87mm
ARP head stud kit
EPP 6mm viton Intake valve seals
EPP 6mm viton Exhaust valve seals
EPP Intake valve seats
EPP Exhaust valve seats
EPP Intake valve guides
EPP Exhaust valve guides
Q45 90mm throttle body
Greddy Q45-RB25 adapter kit
EPP clear cam gear timing belt cover
Tomei oil gallery restrictor orifice
Tomei hi-lift valve springs ~8.8mm
Tomei 256/256 poncam camshaft set
Gates Racing timing belt kit incl. tensioner and idler
2x 700cc Sard injector external intake manifold setup
ryco oil filter, oil filter magnet set & Motul 4100 turbolite 10/40w oil
Need a controller for the extra injectors tho........................
expect, with the sards, there should be enough fuel injc. headroom to push a nice comfortable 230kw tune., with heaps big torque
:P
then thats it, bar pistons/rings and rods/bearings; maybe in 5yrs time. lol
hey Tangles, have you already purchased all the aforementioned head related parts or are you planing to get them.
Different if you already have, but if you haven't, IMHO I would do pistons & maybe rods 1st.........would also be cheaper than all the stuff you've mentioned but only a little more in labour costs
what sort of power has your mates car got if it too much for him :P thought TODA only did toyota parts
will msg you tonight when i get home
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
