well i went to get my tyres fitted on my rims...... 215/40 too stretched for a 9inch rim...
dont go too cheap, Stick with Nankang, Wanli, Hiro, etc.
Surely you jest :P
Wanli and Hiro are some of the shittest out there. A good tyre I've found that grips surprisingly well for its price is the Firestone 'Wide Oval'. Nice grippy compound, yet still seem to wear quite well.
i havent had much trouble with my Wanli's, they just are a harder compound therefore last longer, but im saying if u go cheap, Wanlis and Hero (which Madaz is running) are probably the lowest you should go. Hero's are made by Federal, so they cant be that bad.
Edited by Damo_R34
Lowest you should ge being the lowest of the lot? :P
I've had various types of Wanlis, and they're all crap. The good thing is (like you said) they last ages. I had a pair of rears on the 100 last for 3 drift days and about 5000 road kays. They had absolutely no grip, but you can't argue with that tyre life :(
Maxxis tend to be a lot better tyre for a marginal price increase over Wanlis, and for a little bit more, the Wide Ovals are better again. I'd never run Wanlis or any of the cheap lesser brand tyres on the front, thats asking for trouble. Rears are a moot point in my case, but you gotta run with good fronts.
Edited by AndrewJZX100
AWD for the win then!!! No worries bout traction!! Just put ze foot down
lol Damo............no accounting for taste bud.........Demi Moore @ 50 leaves her for dead
Lady Gaga is a lady hoho
Wearing just underwear detracts eyes from her ugly looks. I think she needs to lose about 5kg too and tone up that lardy body. How come you find that attractive Damo? Your woman is 100x better looking dude. :P
LOL... roo... id take em fertilised at the moment.... (ya hear that ben!) lol
We'll im just in a shit mood today... I ask myself sometimes... y do i have so many male friends and only few female friends...? Then i'm reminded its because THEY F@#$ING SUCK!! Is it a requiremjent for 95 percent of the female population to be f@$#ING BITCHES?
GRRRRRR!!!!!
END RANT. :P
^ so you know what we have to put with then?
Boof: It's not always about traction though. Steering and braking aren't much fun when you haven't got any grip.
And +1 Kralster, well said.
Wearing just underwear detracts eyes from her ugly looks. I think she needs to lose about 5kg too and tone up that lardy body. How come you find that attractive Damo? Your woman is 100x better looking dude. :banana:
I dunno really, just something that screams different but hot :P Oh i dont doubt my mrs is hot!
yes i have the hiro as stated, haven't had to much troubles so far, haven't had tyres worth $500ea either so i don't have a comparison
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
