well i went to get my tyres fitted on my rims...... 215/40 too stretched for a 9inch rim...
dont go too cheap, Stick with Nankang, Wanli, Hiro, etc.
Surely you jest :P
Wanli and Hiro are some of the shittest out there. A good tyre I've found that grips surprisingly well for its price is the Firestone 'Wide Oval'. Nice grippy compound, yet still seem to wear quite well.
i havent had much trouble with my Wanli's, they just are a harder compound therefore last longer, but im saying if u go cheap, Wanlis and Hero (which Madaz is running) are probably the lowest you should go. Hero's are made by Federal, so they cant be that bad.
Edited by Damo_R34
Lowest you should ge being the lowest of the lot? :P
I've had various types of Wanlis, and they're all crap. The good thing is (like you said) they last ages. I had a pair of rears on the 100 last for 3 drift days and about 5000 road kays. They had absolutely no grip, but you can't argue with that tyre life :(
Maxxis tend to be a lot better tyre for a marginal price increase over Wanlis, and for a little bit more, the Wide Ovals are better again. I'd never run Wanlis or any of the cheap lesser brand tyres on the front, thats asking for trouble. Rears are a moot point in my case, but you gotta run with good fronts.
Edited by AndrewJZX100
AWD for the win then!!! No worries bout traction!! Just put ze foot down
lol Damo............no accounting for taste bud.........Demi Moore @ 50 leaves her for dead
Lady Gaga is a lady hoho
Wearing just underwear detracts eyes from her ugly looks. I think she needs to lose about 5kg too and tone up that lardy body. How come you find that attractive Damo? Your woman is 100x better looking dude. :P
LOL... roo... id take em fertilised at the moment.... (ya hear that ben!) lol
We'll im just in a shit mood today... I ask myself sometimes... y do i have so many male friends and only few female friends...? Then i'm reminded its because THEY F@#$ING SUCK!! Is it a requiremjent for 95 percent of the female population to be f@$#ING BITCHES?
GRRRRRR!!!!!
END RANT. :P
^ so you know what we have to put with then?
Boof: It's not always about traction though. Steering and braking aren't much fun when you haven't got any grip.
And +1 Kralster, well said.
Wearing just underwear detracts eyes from her ugly looks. I think she needs to lose about 5kg too and tone up that lardy body. How come you find that attractive Damo? Your woman is 100x better looking dude. :banana:
I dunno really, just something that screams different but hot :P Oh i dont doubt my mrs is hot!
yes i have the hiro as stated, haven't had to much troubles so far, haven't had tyres worth $500ea either so i don't have a comparison
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
