i got a 2009 kawasaki ninja haha
no one will see me car for long time now :)
im very sad
no comments!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
nice bike... whens the funeral
and guys you know that thread mitch posted shes a he :banana:
if you old buggers go this time I could be persuaded to move mountains to attend myself.........I hear so much about it but have never gone............it usually tends to be a stinker of a day (over 40 deg)
Yeah you should go! Luke and I went last year, met up with few of the SAU members who were half way gone by then.. the ciders are way too easy to drink.
what dates it on? I gotta book that weekend off work in advance! :cheers:
im in bangkok atm and there seems to be a lot of white fellas with thai chicks.........they must pay alot!!
guy, did u pick up that exhaust ok??? did u happen 2 see my car there?
adrian, nice rims mate, blick dish FTW!!!! ALWAYS LIKED THAT LOOK
ryan, goodluck on your dyno tune tomorrow, im sure you'll pull 300rwkw
no one will see me car for long time now :(
im very sad
Welcome to the "organ donor" club :D
19 years of riding and I haven't donated yet :D nor have I required a donation! My organs would be too pickled, bruised and battered by now to be of any good to anyone :D
You're welcome to come out Friday/Saturday nights at BP ... just remember, no mucking about. There are no prizes for pissing off the biker boys. :cheers:
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
