i has a question.
got a call from a mate working at a car yard, told me an s2 s14 200sx, 5 spd, stocker, in red has come along, asking $9k, does that seem like a good price?
That's an insane price for an s14a, i think you'll find the market price for them is still around the $14-16K mark.
EDIT!!
On car sale in private listing the cheapest was $12,500 and that was for a auto with 170,000km's, most of them were around the $14.5-17,000.
Edited by D_Stirls
thinking of getting this camera for christmas, can someone tell me if its any good? Nikon Coolpix P80
I basically want a decent camera that will take decent shots (like Vu's camera :) ), but isnt a SLR/DSLR, as im way too lazy to read up and learn about everything im doing.
Canon G10 or G9. Has the features of a SLR but it isn't as complicated - has more of the 'point and shoot' mode, with the ability to turn it all to manual.
Mate has one - they're like 12 or 13 mega pixels. Takes great shots. Can get the G9 for around $700is
Edit: if you want simple... http://www.amazon.com/Oregon-Scientific-DC...l/dp/B000HVVIDA
Edited by CRoNic...
SLR's are remarkably easy to learn the basics. Lens aperture, depth of field, variable exposure rates and manual control over focus is what makes the SLR's so powerful... would take you 2 hours max to figure the controls out, but longer to do the fancy stuff (cause depth of field and what not takes a little while to comprehend if you're not photo savvy)
But eh, its your cash :D
-D
Drove to Cape Jervis yesterday for something to do. Had a P-plater commodore follow me all the way down, up my ass all the way. Nearly wanted to pull over and knock him one afew times. Trying to drift in the hills while your up someone's ass isn't a good idea. Nearly rear-ended me afew times.
Oh and Ryan, I know my desperate attempts to get flamage was piss weak. But with stock motor and boost I'd be lucky to pop some flames. Managed to do it coming down the Express Way yesterday while driving next to a Legnum. He gave me a smile and thumbs up after them so I was impressed.
I'll ask Santa for a PFC for Christmas!
Edited by muirsky
Dang, if they had a Ken camera id snap it up :)
The G10 is awesome - was a wee little bit out of my price range though lol oh and that barbie camera is wikidddddddddd easily the best camera ever! :(
http://au.youtube.com/watch?v=rs-jAImScms
Check this dudes driving....
cretainly appreciated that! imagine what he could do up gorge! the rex was nicelly set up too good coice of wheels
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
