What thermos are you putting in Adrian? I bought a thumping 12" thermo off Ebay to put in my 34 and took the clutch fan out. Biggest mistake ever - cooling is much less effective than the stock clutch fan and shroud. I think it may be cos I didn't put a shroud in with the thermo - not sure. People/machanics have since pointed out to me that Nissan CHOSE to put in the clutch fan setup to suit the car - so it is best not to mess with it. If they though thermos would do a better job, then they would have used thermos when they built the cars.
I am looking for an R34 clutch fan to put back in my car and piss the thermo fan off. It is not performing, and it is so damn noisy compared with the clutch fan.
anyone know if is to take my clutch fan out and remove the pulley for it.. will that be ok?
as im gonna put thermos on!
Mate it doesn't matter how good your thermos are if you remove that pulley as the temp are guaranteed to sky rocket......
It's the water pump pulley. :P
I have just written a response to a similar question on NS... here it is. Oh and someone did a back to back test by removing the clutch fan and it netted 6 rwkw.
People think they're freeing up power by installing thermos but what they don't realize is the extra power draw puts more load on the alternator and the alternator puts more resistance on the turning of the engine so the gains would be extremely minimal if at all. You'll notice the engine revs drop when a thermo fan comes on. This is why.
As Donny has said above this isn't really the point.
Your clutch fan draws power 100% of the time and the more you rev your car the more power they draw, when really you only need it to draw power when the coolant temp rises.
When you are driving why do you need a fan to draw air over the radiator when air is moving over it because the car is moving. I have a single 14" thermo setup on my car and it only ever comes on when sitting at the lights for more than 3 minutes or when moving slowly under high load (i.e. up a hill behind a slow car.......bloody Sunday drivers :) ). This means that these are the only time that the thermos are drawing power from the engine. Even when the car is getting a flogging the temp doesn't move from 87 degrees, the more I flog it the faster i'm moving and the more air flow the radiator is getting.
I also have the thermo set up on a switch in the cabin as well as the thermo switch (two signals to the same pin on the relay), this way when i'm idling the car down i can have the thermo on and drop the coolant temps (not that they'll move much because the thermostat is only starts opening at 82 degrees).
Edited by D_Stirls
thats awsome! im yet to own a car with air con :)
i'll let you fix mine up too :P
Whats wrong with the 32's climate control? ever done diagnostics on it? I can have a look if u like, i think u live relatively close too...
-D
I ran 2 x 12" turbo's they sucked to put it politely. Fine in cooler weather as soon as it 'slightly' warmed up temps began heading north.
Either adapt a set of EL thermo fans or don't bother at all.
Geez!! 2 x 12" turbos - the lag must have been shocking, but I bet they did suck!
:P
I had major problems with my clutch fan flexing and slicing my radiatior open so I got rid of it and did the adjustable thermo fan and its fantastic. Car doesnt get hot, isnt loud and works a treat... but mine wasnt from ebay and had a shroud etc.
    • Yea I could, but it is amusing how shit a stock seat and belt are
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
