whats your plan of attack against the mexicano adrian??? flared guards or trackspec overfenders hahaha, give us a yell when your free, and ill come get that dumppipe too and show ya the new rims:) psi cruise tomorrow night???
well... im gonna get a flare.. cant stand the bolt ons...
um im free all day tomorrow. will be at villies fri from 6ish so u ccan swing past..
if not any day after 5:30. or i can pass it onto ryan?!
ill swing past on my way home tomorrow, bout 5 20 is that cool? :blink:
can someone download me something and burn it to cd or dvd ?
its like 700-800mb
i would download it but my parents aint payed the phone bill so subsequently , no phone line = no ADSL
i cant see this post anywhere but its in my email
was it a legal download if so yes
couple rolla updates
getting a "new" diff for the rolla on saturday :D $30
i must say the petrol tank leak is proving to be moar of a $#@% of a job than i imagined lol.... gonna give it one moar try b4 i just get a new tank for the old girl. might head to "u-pinch-it"
had an offer from a mate of mine to re-spray it too. he said if i supply paint n beer, and lend a hand he will do it. will do this after i grab a straight passenger side front quater panel.
oh.. and did u find those meshies scandy ??
no luck yet mate. few places i couldve left em though, ill let you know.
ill swing past on my way home tomorrow, bout 5 20 is that cool? :)
yeh for sure!!!
let me know when your home tomorrow adrian and ill swing past. Spend some more quality time together. ;)
ill msg u about 3.. gotta get motivated to get the water pump and acc belt :down:
and nissan dont have the hose :)
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
