the sushi place behind the telstra building is so fkn good
massive props to them, they make it fresh to order
Try Ajisen in Leigh st next time u wanna change from sushi. They make the most awesome japanses style ramen.. sushi train on grenfell is ok too
-D
how to ya inc a quote in a sig?
quote it like you usually would, copy the quote -> my controls -> edit signature -> paste -> ??? -> profit
cheers.
yay, the plate i want is available. :(
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
