The weather is looking like shit, and I gotta ride home in it. :teehee:
Hot shower for me when I get home. At least the Brutale gets a wash :D
Oh, and I'm finishing off the rebuild to my pitbike tonight. A few mods, slicks and I'm taking it to the Pooraka track this weekend. Lap record anyone? :(
Edited by RubyRS4
^^ Ruby is the track you speak of at the old 'Megakarts' place (just near Paddys Market)???
I used to go there all the time as a lad, ah memories :(
anyone got cains (? dude with the tt zed) number? i want his advans.
Got it yet? I can PM ya if you want (although I haven't spoken to Conrad in some time now, dunno if he's got a new number recently or whatever)
151 is the strongest legal alcohol u can puchase, being ~76% and a full bottle being 44 standard drinks lol. i dont drink but i see the affects of it all the time.
It must be 151 proof (divide by 2 to get the alcohol % in this case 75.5%)
The stuff we make comes out at about 80% (160 proof) and is almost pure ethanol. The best bit is you dont get as bad a hangover in the morning as there are fewer imputities than traditionally distilled spirits.
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
