Plug in 66% as you had previously or slightly less. Might be worth going a little leaner with 60%.
When cranking go full throttle.
It probably won't start because the plugs are wet fouled then its just a big vicious circle. :S
i tried that the other day to no avail.
Adrian, we need to pull the plugs out,start again..I'll get it going after the job interview.
Edited by Ryanrb25
well.........
the car seems to be running on 4cyl with the new injectors in.. so out the injectors come and off for a flow test... hope two arent f**ked...
oh well we will wait and c how it goes... its all a learning curve!
Checked the injectors are receiving power with a multimeter?
The injectors always receive volts so simply turn the ignition to the on position and check with a multimeter.
The ecu earths the injectors to trigger them so obviously shove the neg of the multimeter on the chassis/battery.
Runs on 4.. Are you sure the plugs just arn't fouled.. Thats what a mate of mines did for a while we warmed it up, raised rev's and she cleared up. :huh:
Not in the mood.. Go and have a bat. lol.
Run it for a good 5mins or so with rev's slightly up.
Make sure the injector correct is set right so go with 'slightly' lean at 65%
.... It could be running for the weekend ...
Another way to check the injectors are firing and when they 'should' be firing is to pull the cas out; ignition to the on position and then spin the cas clockwise slowly when looking at the shaft from behind. You'll hear the injectors click click click. Make sure they follow the firing order. :unsure:
[Vent]
Put turbos back on, sell car?
Pay for removal/reinstallation and just take it in the nuts?
Sell engine, buy R34N1 engine + turbos and apply for an engine conversion?
In SA, that actually seems like a good idea....ARGHHH.
[/vent]
yeh ive done that before but not with the new injectors.. ill give that a crack later..
if there not firing wats the go? there rooted?
[Vent]
[/vent]
how much for the n1's? my car needs a chrissy present
If there not firing its multimeter time to see if the problem is with the loom or the injector.
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
