how much for the n1's? my car needs a chrissy present
If your interested in a cheap pair of N1's mine will be coming off over christmas cause im upgrading to Garretts... only thing the seals need replacing on em as oil is getting on my manifold... so if your interested jus send us a pm if not i'll jus post em up in the for sale section.
yeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeehhhhhhhhhhhhhhhhhhhhhhhhhhhhhaaaaaaaaaaaaaaaa
aaaaaaaaaaaaaaaaaaaaawwwwwwwwwwwwwwwwwwwwwwwww
Just got my 34 back from the workshop. Took it there to replace the water pump, and not only does my car now stay icy cool (old pump was corroded and cavitating badly), but the rattle from my engine bay is GONE! A few of you would have heard the rattly beast on the cruise last week or at bowling a while back - and it is NOT top end issues - it was just the damn water pump. So, no rebuild for me after all!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I am heading down to Vili's to get my calendar at about 7:30pm - will catch up with some of you there
PM sent
well don't nick off straight away, hang around for a bit & I'll try to get down there to
If there not firing its multimeter time to see if the problem is with the loom or the injector.
i can hear clicking on all of them i think.. i just hope there not f**ked otherwise its gonna get expensive!!!!
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
