lol luke, did you remember your handbag :)
yeah had a good day overall today, sold abit at work, made some decent money and then had the win tonight. LOL and we even scored a couple of free drinks cause we had to wait while some dick who thought he was a mafia boss or something tried to give the boss there a serving for dodgey food. Boss gave him his money back, told them it was home time for them and not to come back, was the best handling of a wanker customer i have ever seen!
No,
I was trying to stir him up in the daily on the way home from work last night but he wasn't taking the bait.
It looked like he was running staggered rim widths, i was just wondering how his ATESSA is going? :)
staggered rims are fine if you have the same rolling diameter
Yeah that right but if you have say a 10 inch rim and an 9 inch rim if you don't run the 1 size tyre ie 245/40/?? on both them (i.e 1 stretched one not) you will have problems; and even then if you have a heap of stretch on one and not the other that will effect your rolling circumferance as well.
Sort of correct on the too much stretch
but you can run a 225x45 front on a 8.5 and 235x40 on a 9 inch
there are more width height combo's you can use to get the same rolling diameter but with a inch difference it may be harder to match
Well acording to my calculations there is a 50mm differance in the rolling circumferance between a 225x45 and a 235x40, there's a 15mm differance in diameter.
http://www.1010tires.com/tiresizecalculator.asp
Edited by D_Stirls
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
    • I'm extremely suspicious of the VPP stuff. Best I can tell, you surrender any and all control of your panels and battery to the VPP, because there's no way that anyone could write a sufficiently useful set of "rules" as to how much you would be willing to let out of your export meter at any given time. If one of your main interests is to have enough in your battery every evening to get you through the night without having to import, you could easily find yourself with nothing in your battery at the end of the day, or part way through the night, and then be paying import pricing instead of paying nothing. I cannot see how this cannot come to pass.
    • majority aftermarket is an10 yes, but majority of OEM is An12 r35 OEM cooler lines at close to an 12, the hard line that car uses is almost 20mm  Porsche OEM is also AN12   i figure, if our power levels are close to 1000hp, then AN12 should be a must if many OEM standard power vehicles use AN12
