lol luke, did you remember your handbag :)
yeah had a good day overall today, sold abit at work, made some decent money and then had the win tonight. LOL and we even scored a couple of free drinks cause we had to wait while some dick who thought he was a mafia boss or something tried to give the boss there a serving for dodgey food. Boss gave him his money back, told them it was home time for them and not to come back, was the best handling of a wanker customer i have ever seen!
No,
I was trying to stir him up in the daily on the way home from work last night but he wasn't taking the bait.
It looked like he was running staggered rim widths, i was just wondering how his ATESSA is going? :)
staggered rims are fine if you have the same rolling diameter
Yeah that right but if you have say a 10 inch rim and an 9 inch rim if you don't run the 1 size tyre ie 245/40/?? on both them (i.e 1 stretched one not) you will have problems; and even then if you have a heap of stretch on one and not the other that will effect your rolling circumferance as well.
Sort of correct on the too much stretch
but you can run a 225x45 front on a 8.5 and 235x40 on a 9 inch
there are more width height combo's you can use to get the same rolling diameter but with a inch difference it may be harder to match
Well acording to my calculations there is a 50mm differance in the rolling circumferance between a 225x45 and a 235x40, there's a 15mm differance in diameter.
http://www.1010tires.com/tiresizecalculator.asp
Edited by D_Stirls
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
