finally i think the airport in Bangkok will finally open tommorrow so i can f**kEN come home if not i gotter travel a further 3 hours at 12 am to a military air base to catch a flight at 8am.............i just wanna come home and pick up my car and so Ryan can put my new bakes on........all ive been doin is shopping and wasting money coz im that bored
Could be worse man, at least your comin back....see ya soon!
might be a bit of an out there chance
anyone got a CAD file for the bottom half of an RB20/25 inlet plenum (the runners to the block)
mate of mine is going to be knocking up some custom forward facing plenums, and needs a cad file (or at worst a spare lower plenum half that no-one wants) so he can get started
who's ya mate work for matty? how is he making it?
he works for etsa lol, he's got a bloke who can cut the stuff out of 16mm aluminium
he did briefly explain it but i was driving home from work when he rang me
all good, he had started to mod a standard plenum (until i got highlighted the negative side of that), and he said it was hard to weld new material to existing. was going to be much easier to go all new instead
MAN i just replaced the negative battery terminal clamp... and god damn that was a fricking pain for something hardly significant at all. I cant be ass doing the positive - I'll do it when it becomes a problem. Damn the idiot that designed the battery in the boot directly under the parcel shelf.
ruby those vids remind me of a certain kmart tyre place
now i was in mums sic commo when i was waiting on a very busy to turn right, was there with crazy traffic for like 5min atleast.
finally gap about to happen and i look up at kmart at this fool that appears to be about to snake me and pull out before i can from the private rd. he rolls out sure enough and i notice he aint turning i think who the f is this idiot driving and look in the drivers seat no 1s there :rolleyes: the car rolls by scraps my mums commo on the side and i run after it trying to stop it from slamming into others cars. was having trouble stopping it from the window yank so stupid me stands infront and go's for the rugby scrum stop lukily i got it too stop and it didnt push me over but yeah tools tried to fix up the car half assed when i bailed them out of way more damage to other cars. dudes like fk forgot the hand brake
Edited by Inline 6
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
