Anyway ...
Removed the chicken shed, fencing and cut down almond tree in my back yard. Ready for the pool to be installed on the Saturday. :D
Bobcat guy coming back to clear a bit more of the site, then it begins ... it'll be erected and filled before Chrissy!
Also, paid for materials for house extension. Materials coming in the next couple of weeks. Currently boring the holes for the foundations. Got my 'laser level' and all the cool tricks ready to go.
Anyway ...
all the best in whatever you get up to Joel, I'm sure it's just a semi departure from here, not events hopefully, so hope to try & catch up at the Christmas picnic & dyno days etc.
I've been on the boards for just over a year and don't ever recall any unfair attitude from you, Andrew or Matt........people have to accept that certain issues do require a firm measure of handling otherwise it becomes a free for all. People also have to realize that you guys are partially responsible for a clean reputation of SAU which unfortunately sometimes requires unpopular decisions.
Pete, tomorrow's weather is 24 and sunny (fine). Bringing the beast out to Vilis?
I'm itching for a ride, and may not have time on the weekend, so I'll be riding to work tomorrow and Fri night. :D
BTW found a neat accessory for the bikes Pete ...
Edited by RubyRS4
think you all need me as a mod, im fair and im awesome
/blows own trumpet
on other news, i finally found a 32/36 DGV weber for the rolla :D it comes on a manifold, with adapter plate n all
bargain as well, got it for $80, when other ones similar are going for about $150 on ebay, without all the fruit that is on this one
im stoked to say the least
Almond tree's grow back!! We got one out the front cut down and even the main trunk and roots pulled up a couple of years ago and we're still getting little mini-trees popping up!
Not this one when I'm done with it :D
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
