who on here works for ''y climb'' ????
matty T does.
Victor harbour for me tomorrow night woo. Alcohol Check, money check. woo
my boss owns y-climb, the company i work for (electel) use their trucks
why's that craig?
nah craig, they woulda been our north depot guys either going to or coming from a job down near ASC
im workin at ETSA St Marys depot atm, get to share my carpark with 2 tough 32s and a tough FC
lol, in my company car, i prob would have been flipped the big one lol
EDIT: haha jarrad, long time ago, long story,... well, several long storys.
:P
Edited by craig R33
hey just a quickie
if you had your bonnet open while working on your car and it was raining a lil bit...not heavy. and your filter may have got a lil bit wet would it cause the car to idle funny, as in revs drop a bit and sounds like its missing????
cheers
ahh k coz was getting a head light changed over at adel jap imports..n the guy was workin on it out side n was going to swap it over but then didnt coz he would have to take my bar off and didnt wanna scratch it or anything so he put it all back together but now on idle the revs drop n if i give it a bit of gas while idleing it sound slike its missing but when driving its fine.
I did start it straight away tho after he was finished as i had to go but the filter didnt look like it was wet but could of been coz of the rain...hopefully he didnt touch anything.
Edited by vinnie32GTS4
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
